cartek heads milled .30
Old 12-30-2006, 03:12 PM
TA1972's Avatar
Default cartek heads milled .30
Hi, Wanted to know if i put these cartek x2 ported ,milled .30 heads with my 224/224,588/588,114 cam on to my 99 ls1. What size/length pushrods and what height head gaskets do i use or can i use newer stock head gaskets? Please help
Old 12-30-2006, 03:41 PM
JPH
JPH's Avatar
shorten the pushrods up .030, unless you want to use alot thicker head gasket to make up the difference. you can offset these differences a little with moving things up or down, but if you use stock gaskets, i would shorten the pushrods.
