HP and changing lifters and rockers
Old 01-02-2007, 07:43 PM
Phil'sC5vette's Avatar
Default HP and changing lifters and rockers
Im just curious, but at what level of HP or cam lift should you change the stock lifters and rockers.
Old 01-04-2007, 06:43 PM
lol
Old 01-04-2007, 07:06 PM
Doc99SS's Avatar
Phil,
I think that the factory hydraulic roller lifters are excellent pieces. I have run the stock ones in my highly modded '87 IROCZ for 18 years. And in my '99, I have documented 400 RWHp and trap speeds of 117mph and shift at 6500 rpm, they have held up very well also. However, I think that the stock LS1 rockers will suffer a needle bearing failure. Some I have read on here at about 80,000 miles, but then again, these are highly modded engines.
Does this help ?
Old 01-05-2007, 06:08 AM
Yes it does. I have a weekend cruiser with 410 RWHP and 21000 miles.
I was wondering when I should get concerned about the rockers and lifters
Old 01-05-2007, 07:05 AM
KY Z28's Avatar
I upgraded to the LS7 factory lifters in my car. They should be good for about anything most people will throw at them and they are cheap, less than $100 for a set. If you are really worried about the rockers, just send them to Harland Sharp and have them rebuild them for you. Again, thats about all most of us would ever need.
Old 01-05-2007, 11:34 AM
vettenuts's Avatar
I have a completely different philosophy on all of this, one that many won't agree with. When you install an aftermarket cam, you lower the base circle and thereby lower the lifter in the bore. The stock lifters have shown on occasion oil starvation issues as a result. I went with Morels to ensure that this didn't occur since in their development work they ran into this same problem and corrected it.
As for the rockers, I couldn't get a decent wipe pattern out of the stockers and have gone to roller rockers as a result. The bearings were less of a concern then was the potential for accelerated guide wear with a rocker that wasn't placed correctly on the valve stem and much higher spring loads. Again, stock rockers are good pieces, but they were designed for lower spring loads and therefore the tolerance on the wipe pattern was not as critical. Start upping the over the nose spring loads and wipe pattern gets more critical in a hurry.
None of this is related to hp but rather the installed setup of the valve train you are running. Z06 valve springs will provide good hp with the right cam but don't provide nearly the valve train loads as something like Comp 921's.
Old 01-05-2007, 03:33 PM
KY Z28's Avatar
I dont think too many people would disagree with you per say. Some might think that is a bit overkill, but to each their own.
The issue with the lifters being lowered .050" is probably not a serious concern unless you are talking about a max effort engine. The rocker issue is about the same. That said, the details are what makes the difference...
Old 01-14-2007, 08:12 AM
Really, Im not looking for additional power out of them, im looking more towards what are failure points, and if im pushing my luck with current stock lifters and rockers
Old 01-14-2007, 01:21 PM
heavymetals's Avatar
Your pushing your luck more with the stock valve springs.
IMHO if your going to do anything, change the springs first.
Rolling rockers? YES
I am using the Comp Cams #1500 rocker system and it is the "bomb".
Old 01-14-2007, 01:25 PM
cablebandit's Avatar
i prolly should change mine but i still got stockers on 820/823 rwhp/rwtq. My cams are small though...230 or lower......600 lift or lower with 921 springs. My rockers got 90k miles and the lifters 20k
Old 01-21-2007, 08:59 PM
rez0469's Avatar
Do you or can you gain more HP from different rockers?
