G5x3...shifting and rev limiter?
Old 01-10-2007, 11:30 PM
badaz28's Avatar
Default G5x3...shifting and rev limiter?
I recently installed the x3 114, PRC duals, and comp pushrods. What is a good and safe rpm to shift at? I was thinking 6800, does that sound about right? also, if I am going to shift at 6800, should I set my rev limiter at that speed or maybe a bit higher like 6900?
Thanks.
Old 01-11-2007, 12:21 AM
sidewayz28's Avatar
wowzas your going to wind that motor up... you got a dyno graph?
Old 01-11-2007, 12:38 AM
DONAIMIAN's Avatar
If your planning on shiting at 6800 then the limiter should be set at 7k or 7.1k inorder to give you time to react and acually shift. I have no doubt that the cam will make power that high.
Old 01-11-2007, 12:22 PM
N4cer's Avatar
Yeah that 114 should carry there for sure. That's why I got it on a 112 though. To shift at 6800.
He's not spinning that high. All the local stock bottom end LS1 cars spin to 6800-7k. They can handle it just fine everywhere except the internet.
Old 01-11-2007, 12:26 PM
nexvctm2001ss's Avatar
......waiting wondering the same thing
Old 01-11-2007, 12:31 PM
N4cer's Avatar
Waiting for what?
Old 01-11-2007, 12:35 PM
4 u 2 check your pm
Old 01-11-2007, 01:51 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I don't know about you, but I can't **** at high RPMs for...well...****. Sorry...I had to.
Old 01-11-2007, 04:52 PM
sidewayz28's Avatar
"All the local stock bottom end LS1 cars spin to 6800-7k. They can handle it just fine everywhere except the internet."
well DAYAM i need to raise my RPMS too then!
Old 01-11-2007, 05:26 PM
allngn_c5's Avatar
I personally only try to push to 6600 rpms, but that's just me. Lots of power up there. Not sure how much more power you are making going a couple extra hundred Rpms, but whatever you decide is up to you. Good luck, and I hope you love this cam, I know I do.
Old 01-11-2007, 08:07 PM
badaz28's Avatar
Thanks for the responces. Im not getting dynotuned until another week, so I guess I'll look at the numbers and decide from there. I heard this cam makes power to like 7200rpm, but I need my motor to last so if the numbers are high enough at 68-6900 I will shift at that and set my limiter at 7k like Donaiman suggested.
Also, are you guys using a shift light or other tach or just stock tach?
Old 01-11-2007, 08:14 PM
N4cer's Avatar
Stock tach, listening to motor, and sometimes that tat-tat-tat-tat sound.
