On cam-only can heads be milled?
When people go for cam-only set-ups, are stock heads milled still considered stock (cam-only)? I guess as long as they are not ported?
A lot depends on howmuch cam you are planning to run, and whether or not you plan to replace the heads down the road. If you will not be getting heads later, then I'd say do it. It's your car, mod the way you want. But if you post a good dyno number & tell people in this forum that its cam only, expect a or two.
I've thought about doing it too, since it's hard to get a 8.0+ DCR with a decent size cam otherwise. But I'm pretty sold on AFR 205's when my money tree starts blooming
