will this work? should i worry about PTV clearance?
MTI Stealth II 224/220 .581/.581 116+0
Patriot CNC-ed LS6/243 casting milled to 62cc (the ones on their homepage)
Cometic .040 MLS gasket 3.910 bore
figuring 11.33:1 comp & 8.43 DCR
or would i be better of going going more conservative with
Cometic's .045 MLS gasket 3.905 bore
> 11.18:1 comp & 8.32 DCR
also should i run stock length pushrods too (7.400)?
which pushrod?
comp chromemoly
TR chromemoly
TSP chromemoly
are there differences? or spend the $20 else where?
which pushrod?
comp chromemoly
TR chromemoly
TSP chromemoly
Your PTV should be fine with that setup. As for pushrods you can use a pushrod length checker and find out exactly what size you need then buy the rod thats closest to that length.
Originally Posted by BlueOvalEater
how friendly will the 11:33 or 11:18 SCR be with pump 93 octane
