Does this look right..add/remove?
I am doing a LS6 swap into my 98 T/A Convertible, A4, with 3.90 gears.
I am about to place an order for some new parts, tell me if I am missing anything for a cam swap and tranny upgrade..
Cam
1. Comp Cams Xtreme RPM 224/228 .534/.537 112 LS, (2000-6800 RPM)
2. Crank Pulley Bolt
3. LS2 Timing Chain
4. Patriot "Gold" Dual Valve Spring Kit
5. Comp Cams Hi-Tech One-Piece Chromemoly pushrods, 7.400"
Tranny
1. TCI 4L60E Super Street Fighter 3000 Torque Converter (edit)
2. V8 B&M 4L60E Transpak Shift Improver Kit
3. New Torque Converter, Flywheel, Pressure Plate Bolts
Anything I might want to change or add please let me know.
Thanks!
Cam
3. LS2 Timing Chain
Tranny
Thanks!
Is that a 4000rpm stall? If so I would reccomend calling TCI to see what they say to match your cam and setup. I have a similar setup 224/228 .585/.585 114 with a loose Vigi 3800 and I want something smaller like 3200. People told me go no lower than 3600 but it makes for lower mpg and my converter isn't matched well for my cam. You'll get used to it but I would talk to the converter manufacturer and go with what they say not what others tell you.
Also you'll need hardened push rods and gaskets. Lifters depending on the mileage and age of your engine. My stock lifers started giving out and I bought the new Crane lifters that are like the Morel ones.
