L92 Heads/L76 Intake
Old 01-22-2007, 02:54 PM
ChrisUlrich's Avatar
Default L92 Heads/L76 Intake
I think those are the model numbers...
Has anyone install them without porting? Basically going with a cam only LS1 then bolt those heads/intake on?
I am wondering how much more power i'll see from that setup on my stock LS1.
Old 01-22-2007, 03:23 PM
12secSS's Avatar
You will loose all power, as the intake valve will collide with the LS1 cylinder wall. You can not use those heads with anything smaller then a 4.00" bore, the intake valve is 2.15".
Old 01-22-2007, 06:40 PM
Aren't the bores of a stock LS1 4"?
Old 01-22-2007, 08:24 PM
SUTTERERMAN85's Avatar
3.898" stock bore. 6.0l block is 4.0"
Old 01-22-2007, 08:25 PM
actually the intake valve is 2.16" not that is matter too much
Old 01-22-2007, 11:37 PM
Beast96Z's Avatar
Yep, 6.0L block or better for these heads.
