What advance would you install this cam at?? Patrick G?
The motor is as follows Ross forged pistons w/ 4cc reliefs, Patriot 59cc heads, cometic .040 gaskets and this cam: 244/248 .617/.622 109+6
The cam card is attached for the exact info.
I was planning on installing it 2 degrees retarded but was looking for some other opinions.
I will also eventually be spraying a 200 shot w/ this set-up so advice on timing for that would be greatly appreciated also.
LS1 Tech Administrator
That cam would probably be OK to install dot to dot if you're looking for a big torque number in the mid-range. If you're after more top-end, I would retard it 2 degrees and install it at 105 ICL. That would rock!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I ran it straight up last fall but never made it to the track. It had a ton of midrange but seemed to fall off rather early. Looking to move the RPM range up but not so much that I lose all of my torque.
