Anyone running a trick flow cam?
Old 03-16-2007, 09:28 AM
SERIALPIMP's Avatar
It is so hard to tell the difference between all these cams without getting the detailed specs for the ramps, to tell side by side how much lift at what point in the rotation, They are all so close, when just looking at max lift/duration/LSA
Does anyone know where I can get his information?
You can have two cams with same max lift and similar duration behave differently, I would not say extremely differently, but I would say materially differently.
When I got my Crower for my other car, they went over the details with me on the phone and we matched my Cam and the Ramps, and everything exactly to my Dart Heads, their intake runner size, flow numbers, engine, bore to stroke ratio, everything I feel determines the powerband and resulting performance. I credit that due diligence for above average performance and hp/$ that my other motor, a 383, makes in my 79 Camaro.
My $3,800 383 w/Iron Heads, cast steel crank, factory rods, w/hydraulic flat tappet at 3680 lbs. w/driver and small headers, stock ignition, 3.42 gears ran 12.36@108 when I first dropped it in back in 1998 or 99.
Old 03-18-2007, 10:34 AM
SSDoubleK's Avatar
Let me know how it is once your done. Thanx.
Old 03-20-2007, 11:53 AM
SERIALPIMP's Avatar
Looking forward to seeing some results of these cams with and without their heads.
Old 03-20-2007, 01:54 PM
GrimReaper's Avatar
Cant wait to see the results, very interested in how the TFS cams do.
Old 04-01-2007, 11:08 AM
SSDoubleK's Avatar
Any results on how the cams are behaving power wise?
Old 05-16-2007, 09:55 AM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Back from the dead but on topic. I finally got my car running and I will be getting it tuned shorty. I have the largest of the 3 grinds. RX7. stock LS6 heads and intake. Pulley. 1 3/4 long tube headers. Anyone care to guess what kind of power it will make?
Andrew
Old 05-16-2007, 10:48 AM
Icetech's Avatar
390.... who grinds these btw?
Old 05-16-2007, 10:57 AM
NemeSS's Avatar
who grinds the cams for trick flow?
also how agreesive are the lobes.?
anywhere near the comp xe-r or lsk?
Old 05-16-2007, 11:18 AM
Given the relatively low lift numbers compared to the duration, I would say that the lobes are not very aggressive. However, I do not know that for a fact.
Andrew
Old 05-16-2007, 12:55 PM
Mike@TEA's Avatar
Although I am not at liberty to disclose who grinds those cams, I will tell you it is major camshaft grinder out of Tenn. (not Comp) so the quality is good. The camcard is a dead giveaway since theirs is unique . I know the lobes are not nearly as aggressive as the xer's. When the engineers at TFS were developing the cams they wanted camshaft's that made good power with no reliability (valvespring) or valve float issues that could lead to warranty problems
Old 05-16-2007, 10:21 PM
I should have some numbers tomorrow.
Andrew
Old 05-17-2007, 02:24 PM
  #32
I am very pleased. Made some pulls. Cleaned up the idle. Realized that my little air filter was too small and was creating a restriction in the MAF. Open headers.
After the tuning the pulls settled in the 405-408HP range with torque around 400.
I am pretty happy.
Andrew
Old 05-17-2007, 10:20 PM
  #33
RIDINFILTHY's Avatar
i have the biggest one and i love it,cheap and they get the job done i put down 360hp with it with stock heads and intake, just headers and i have a stalled auto!! i think lunati grinds them
Old 05-17-2007, 11:11 PM
  #34
motoo344's Avatar
I am pretty happy.
Andrew
Those seem like good numbers! Did you use the stage 3? How does the cam idle? Im thinking about a cam package from texas speed, but this cam is 120 dollars cheaper.
Old 05-19-2007, 11:31 AM
  #35
SSDoubleK's Avatar
After making the post, I went with comp cam, I'll post my results once I get around to installing the stuff. Thanx for all the input.
Old 05-19-2007, 04:56 PM
  #36
5150mechanic's Avatar
A very helpful person at TEA highly recommended the trick flow cams. Very, very smart guy. He told me don't beat myself up over a few Hp, that there is not one "magical" cam thats gonna make 50hp over everybody elses. If you pretty much know what area you want your cam to be, they will all be pretty close. Then he let me know I'm letting about 45hp go due to LQ4 pistons and 70cc heads. Getting back to the topic, they liked the TF camshafts for the buck.
Old 03-16-2017, 09:05 AM
  #37
MulletWagon88's Avatar
Thinking about putting this cam in my stock lq4. The TFS-30602003 is the same as Jegs 200582. To those who are running this cam, what gears and stall are you running with it?
Old 03-22-2017, 04:12 PM
  #38
Bspeck82's Avatar
10 years later
Old 03-22-2017, 06:10 PM
  #39
Originally Posted by Bspeck82
10 years later
Whoops, didn't even notice that....
Old 07-11-2018, 06:14 AM
  #40
zukboi2004's Avatar
Default Night of the living dead 🧟dum♂️
I am running 3:50’s with my Turbo car and this cam
waiting to get Dyno numbers
Quick Reply: Anyone running a trick flow cam?
