HV Oil Pump due to SC and Oil Cooler
hello,
I've got my hands on a used Paxton Novi2000 SC, since the Paxton's are not selfcontained like the Prochargers, someone told me, that it would be a good Idea to get a HV OilPump, I also have a OilCooler, so once the SC is Installed there will be more oil in the system that needs to be circulated than in a stock motor.
I also heard somewhere that a HV pump will pump all the oil to the heads and draw air from an empty oil pan, 'cause the oil cannot go back down as fast as its being pumped up, is that an issue with the LS1's?
Now, what do you guys think, good Idea or just waste of money and time?
