Newbie question?
Old 02-21-2007, 11:21 AM
transam69230's Avatar
Default Newbie question?
I did a search and couldont find anything. What is flycut? i am installing a cam, and keep seeing people say you will need to fly cut the pistons. Will i have to flycut my pistons with this cam 234/242 .600/.610 LSA 110+2. This is going with 243 castings with PRC gold dual valve springs, and stock valves that came with LS6 head. I had no clue going into this. Right now i got the heads off, and waitng to get the crank pulley off, but my air compressor is too small.
Old 02-21-2007, 11:24 AM
brad8266's Avatar
Flycutting is when you cut into the tops of the pistons in order make more room for your valves.
Old 02-21-2007, 06:33 PM
JPH
JPH's Avatar
degree the cam, then check ptv. i would check, it should clear, but i would measure on how much it clears by. min of .070int./.090exh.
