Heads and Cam combo..??
Originally Posted by SSmokin99
Since I live in California I was thinking of getting a 224/224 cam on a 114 LSA. What heads would u recommend to go with that cam? I was thinking of the AFR 205's...What do you guys think?
Will I get as much power out of the PRC heads than the AFR?
True test is at the track and AFR's are proven again and again but if you want to spend less then the new prc 5.3 is a damn good way to go.
AFR's are a premium head and you wont go wrong buy buying them.
PRC is great bargain and put out equivelant numbers to the more expensive aftermarket heads and are a great value. Same as Patriot
Originally Posted by eminem1833
i have also TR 224/224 - 112 cam with full bolt on ,,,
I was thinking of the LS6 ported or L92 ported or
5.3 ported heads ...What do you guys think?
If you can swing the AFR 205's I have seen some great results with those heads and that exact cam you already have. You can probably find some info on that combo in the dyno section.
Im an A4 and have tr224/112 cam and Tsp 5.3 heads and ported fast 90/90 and put down 410rwhp and 400ftlbs so far.The reason i say so far is cuz on the dyno my driveshaft crapped out and it was still climbing,but i just got off the phone with my shop and got my drive shaft back on so im gonna see if they squeezed more out of her.You can go to the dynamometer section and do a search on my thread "A4 Tr224/112 TSP stage 2.5 5.3 heads ported fast 90/90" to see my dyn graph on my last pull
got my car and it put down 417rwhp 407ft
