I need help picking some heads...
I know people are going to hate me for making a thread like this but i just cant make up my mind. I dont want to spend 2k for heads just like 1-1500. I was looking at TSP and some of their heads:
PRC ls6 heads
PRC ls6 stage 2.5
One of their 5.3 heads
Any other suggestions?
I was also thinking of getting a little bigger cam to go with my heads. I ahve a 224 now. My shift points are 6k and i do not want to go any higher than that since i still have stock tranny. So if you have any suggestion on a h/c setup please let me know. I would like to see over 400. I have all bolt ons with 3600 stall and 3.73 gears. I never dynoed it but i figure i have around 380 now, i raced a cobra with 420-430 and stayed exactly side by side.
Thank you.
PRC ls6 heads
PRC ls6 stage 2.5
Thank you.
you are probably alittle shy of 380 right now because of the auto but if you go to a bigger cam you will need to raise your shift points also or you would be defeating the purpose of a bigger cam.i'd go with a set of heads that has a small runner like an afr 205 which has high velocity to keep all that midrange power.i don't think you will improve performance much with a set of ported heads and bigger cam unless you raise your shift points to atleast 6300-6500.
my .02
my .02
yea that is why i am not sure of going with a bigger cam...i have to be close to 380 to stay with a 420-430 cobra from a roll...i dunno i should dyno sometime thanks guys
