P.T.V. Clearance on a LS1. Am I pushing it?
Old 02-28-2007, 08:55 PM
gearjammer78's Avatar
Default P.T.V. Clearance on a LS1. Am I pushing it?
I have a LS1 with a stock bottem end. I'm putting LS6 heads that will be ported and polished only, stock valves and no milling done. Plus a TSP Torquer V2, rocking a set of Crane Cam shaft mount roller rockers 1.7:1. I ordered a pair of Cometic .040 head gaskets. Am I safe, or will I need to have the pistons flycut? I know im safe with stock GM gaskets which I have, but I am always looking for more.
Old 02-28-2007, 09:15 PM
Xtnct00WS6's Avatar
I'd think you'll be alright. For peace of mind, it's best to measure.
Old 02-28-2007, 09:40 PM
JRracing's Avatar
I would bet that you will be OK.
Old 02-28-2007, 10:19 PM
thanks, I will check it to be safe, I just wanted to see if any one else had any first hand experance with the same setup, one more question will that change my compression ratio any
Old 02-28-2007, 10:25 PM
JRracing's Avatar
The thinner gasket will raise the CR.
Old 02-28-2007, 10:58 PM
ssfast99's Avatar
the .040 gasket takes away ptv but you should be okay. be careful though because aftermarket rockers are true ratio while stock have a tendency to not always be accurate.
Quick Reply: P.T.V. Clearance on a LS1. Am I pushing it?
