Head Gasket Size
Head Gasket Size
I order a torquer 2 cam kit to go along with the Thunder Racing GTP Stage 2, 60cc chamber, 2.02 & 1.57 valves, heads I have. My question is what size head gasket will I have to get? I know you can order the GM gasket set from TSP but I think that has the stock gasket size in it. Any input welcome. Thanks in advance.
Check with Thunder Racing, for their reccomendation, I am not familiar with the dur or lift of this cam but PtoV should be a consideration with the heads cut to 60cc.
With .585 lift and 226 dur. with 64cc heads installed with .045" gaskets, I had no problems with clearance.
DD
DD
