Stroke ??
Old 03-24-2007, 09:32 PM
ccx2zu's Avatar
Default Stroke ??
Is it possible to use a 4.00" stroke in a 5.3 ?? If not what is the maximum stroke? I have been searching and searching for anything on this and can't find anything. So hopefully someone knows. Any help will be greatly appreciated!!
Old 03-24-2007, 10:21 PM
Tainted's Avatar
you may have better luck finding this in the interal section, try posting it up there or have jordan move this thread for you
Old 03-25-2007, 01:49 PM
427's Avatar
The 4 inch crank will go into the 5.3 block with no problem. You will need the right rod/piston combo to make it work.
Kurt
