Head Question
Old 03-28-2007, 02:59 PM
NC98Z's Avatar
Default Head Question
If you took a cam only car and ran it on a dyno and then changed out the heads to LS6 stage 2s and redynoed it when you looked at the dyno sheet would it show a power increase all the way across the rpm range or would it look basically the same at lower rpms and show a big increase at the top end?
Old 03-28-2007, 03:01 PM
brad8266's Avatar
It would probably make more power everywhere, although the increase would likely be more prevelant in the upper RPM range.
