Spec difference between 02 LS1 and LS6 cams?
Re: Spec difference between 02 LS1 and LS6 cams?
Here are the specs for the 2 cams:
002 LS1 Cam Specs:
Valve Lift (int/exh) - .467"/.479"
Duration @ .050" Lift - 199°/210°
Lobe Separation - 116°
2002 LS6 Cam Specs:
Valve Lift (int/exh) - .525"/.525"
Duration @ .050" Lift - 204°/218°
Lobe Separation - 117.5°
002 LS1 Cam Specs:
2002 LS6 Cam Specs:
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by parts@sdpc:
<strong>Here are the specs for the 2 cams:
002 LS1 Cam Specs:
2002 LS6 Cam Specs:
Lobe Separation - 117.5°</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have the 2002 LS6 (Z06) Cam specs to be -
2002 LS6 Cam: 204/218 .551/547 Int CL:120
Exh CL:115 LSA:117.5 Cam Base Circle 19mm
002 LS1 Cam Specs:
2002 LS6 Cam Specs:
