Need help identifying my LS1
Old 11-30-2002, 05:21 PM
mike LS1's Avatar
Default Need help identifying my LS1
I just purchased a brand new LS1 engine in a GM crate I would like to find out what car this engine was intended to be installed in? There are no numbers on the block other than the casting numbers by the fly wheel witch are 12559378 and there are 3 sets of numbers stamped on the heads witch are 2111002,0342qk and 606856. This engine came with a fly by wire throttle body but the exhaust manifolds and oil pan look like Holton parts please let me know if anyone can help me identifying this engine.
Old 12-01-2002, 09:28 AM
LS1swap's Avatar
Default Re: Need help identifying my LS1
No problem all the info you will need is on the block, but it is not either of the numbers you have posted. You need the VIN derivative it is laser inscribed on the block. It is located on the side of the flange the opposite side that the starter mounts to. I will use mine as an example 1W2132624
1 represents GM division 1= chevy 2= pontiac
W represents model year in my case 98
2 represents assembly plant in my case St. Therese
The last six digests represent plant sequence
From this I was able to tell my was a chevy.....98 model year....built in st therese( all f bodies are).... And the last six digests of my actual vin are 132624
Vin derivative pos. Equivalent actual vin pos
1 3
2 10
3 11
4-9 12-17
So you start inserting these
X X 2 X X X X X X W 2 132624
Now to Finnish it up
The first digit of the vin represent country of origin 1= US
The second represent manufacture g = GM
The third represents division 1=chevy
The fourth and fifth represent car line yy= corvette fp = camaro
The six body type 2= hatch back 3 = convertible
The seventh restraint system 2= air bag and manual belts
The eighth engine g= LS1 I don't know the letter for LS6
The ninth is a check digit I used 0 and it worked for me
The tenth is model year v= 97 w=98 x=99 z= 2000 I don't know what they did after that
The eleventh is assembly plant from the derivative we know that is st therese in my case
The twelfth through seventeenth is plant sequence from the vin derivative we know that is 132624
1G1FP (just have to guess at this one I guessed 2 hatch back) 2G( I guessed 0 and it worked) W2132624
2G1FP22G0W2132624
I ran a car facts on this and it came up as a z28 camaro
Then I went into the dealer and had them run the vin to see what warranty work had been done
Hope this helps good luck
Old 12-01-2002, 09:38 AM
LS1swap's Avatar
BTW the 12559378 casting number means it is a 350...01-up...crossbolted block, Gen.III, "LS1", aluminum, and the fly by wire throttle is a vette only option you are going to need the PCM and vette gas peddle to make it work
Old 03-20-2005, 02:06 PM
Stu Cool's Avatar
This thread is a great help to me, would like to make a correction and addition to the year codes. y=2000, not z. 1 = 2001, 2 = 2002. For the ninth check digit, in addition to 0 (zero) I also found x and 8 are used sometimes.
I used it to decode a 2000 Firebird LS1
This motor had a block casting number of 12559378, so that number was used before 2001.
Thanks for your help
Pat
Old 12-04-2015, 08:00 AM
1100kaw's Avatar
Default Engine Derivative VIN de coding
I have found multiple old posts like this one. (10yrs old.) but cant find anything recent.
Obviously they have changed the system a bit.
Is there a way to figure out what the newer stuff is exactly? year? make? size? etc...
I have 2 engines I would like to identify. The numbers I have are nothing at all close to the examples I am finding.
These numbers are lazer etched/stamped on block, drivers side. cylinder head deck surface where transmission bolts. Above oil filter.
1st number C7G508093
2nd number T36199444
My understanding is. 4 of these numbers match the actual vehicle engine was in.
Is there a way to find the actual VIN with these few numbers as a starting point?
I do not have the ECMs. Just engines.
Thanks for looking
Darrell
Quick Reply: Need help identifying my LS1
