Another LS6 Head question?
LS6 Style Patriot Stage2 heads, will these bolt right up to a LS1? It will not let me do a search, page keeps coming up blank. Want to make sure I can still use stock push rod length and rockers with some factory GM gaskets. THAnx for the help.
yes you can use stock gaskets. and these will bolt in. they are a direct fit. as far as the push rods go it depends if the heads have been milled at all. You can use the stock rockers though. Good luck
