head bolt ?
Old 04-10-2007, 08:12 PM
quick346's Avatar
Default head bolt ?
I read it all on the ls1 how to site. so there is no oil or lube used on the bolt's? just the locktight that is on the bolts. is that right?
also do i even need to check the p.t.v.c with a tr224 cam with 59cc afr 205's?
I know i should and prob will but i can't see how that duration and lift could be a problem even with the mill on the heads.
after my little 2 day dropped the oil pump bolt prob.I def don't need any mistakes.
also no copper spray is needed for the gm gaskets right?
part#12498544
