Cam Swap - Gaskets?
Old 04-12-2007, 08:09 PM
jinxedz's Avatar
Default Cam Swap - Gaskets?
Swapping the cam on my car soon. Also taking the heads off to replace the lifters (and make it easier to do the springs while I am at it).
What Gaskets should I pick up?
Below is what is going in:
Camshaft
LS6 ported oil pump
LS2 timing chain
pushrods
springs
lifters
March UD pulley
Redtop SVOs
The engine has 120K on it.
Figure Id do the headgaskets while I have the heads off.
What else?
Thanks.
Old 04-12-2007, 08:38 PM
blkZ28spt's Avatar
Check "cam swap" link in my sig for my general advice. 2-3 years old but still good.
Need a new water pump gasket, valve cover gaskets are fine to re-use.
Don't forget both a longer crank bolt for installing the pulley and a brand new, unused crank bolt of proper/normal length for final in stallation.
Old 04-12-2007, 09:46 PM
NviouSS's Avatar
just pick up one of the gasket kits from texas speed.
Old 04-13-2007, 08:37 AM
jinxedz's Avatar
Thanks guys
NviouSS - I get employee discount at GM, makes sense for me to go through them
