Trashed Ls1 block!!
Old 04-16-2007, 09:43 PM
bwil6488's Avatar
Default Trashed Ls1 block!!
FTW! I trashed my ls1 block! A valve broke and dropped into cylinder 2. So I need to know what block to use with my Patriot Stg 2 59cc 2.055/1.57 and trex cam. Should I use an iron 402 Ls1, a ls2 aluminum 402, an ls1 383 or an ls1 iron 408? Which would be the best with my current H/C. What about the interchangeable parts with the Ls2? Thanks for the feedback and opinions!
Old 04-16-2007, 10:47 PM
nmp27's Avatar
Same thing happened here...
Went with the LS2 402
Old 04-16-2007, 10:50 PM
mvvette97's Avatar
Are the single springs breaking? Why are these valves falling?
Old 04-17-2007, 08:53 AM
magius231's Avatar
says here valve broke. I would hope he wouldn't be running a TRex with single springs anyway.
Old 04-17-2007, 09:36 AM
bwil6488's Avatar
ptv clearance issue. Ran great for a couple hundred miles.
Old 04-17-2007, 03:28 PM
bwil6488's Avatar
So which engine should I go with??
Old 04-17-2007, 08:51 PM
67Ranger's Avatar
402 if you can afford it, 408 if you want to spend a little less money. If I could do it again I would have definetly go with a 402, or maybe even a 414 (L92 block) if you have the money.
