Re-use pan and cover gaskets?
As the title states I am wondering if anybody has had success or failures reusing the front, rear, water pump, and oil pan gaskets?
Thanks
Thanks
picture it this way, if the engine is already out, replace them all. If the rear, or the oil pan seal looks good, and you reuse it, and it leaks later on, you're going to have to either drop the trans for the rear seal, or pull the motor to replace the oil pan seal . . . not really worth it
