RTV around the knock sensor plugs (search didn't answer my Q)
Any drawback to putting the high temp RTV around the parimeter of the plastic plug that protects the knock sensors? Seems like a better seal than the dam described in the TSB.
Maybe its a bad idea because IF water did get by the seal, it wouldn't dry so fast, thereby causing rust in a bad bad way.
Any thoughts?
Any thoughts?
