02 241 casting heads..what should i do with them??
Old 04-24-2007, 10:45 PM
leoni62486's Avatar
Default 02 241 casting heads..what should i do with them??
hey guys i recently aquired a extra set of heads from an 02 z28, i have a 02 ss, im plannin on doin a cam in the future, like torquer 3 possible or the mti g1 cam....heads are stock, but what would u run parts wise, springs,lifters?? like anything and everything to run a beefy cam like those?? im gonna get them ported and such and specs on what to tell them when i do??? also what about rockers??? what i do about those i would like all input...im plannin on gettin ta ls6 ported oil pump seein everyone else thats cammed has htat and the LS2 timing chain..lemme kno guys, thanks...
Old 04-24-2007, 11:59 PM
GR33N GoblinM6's Avatar
i got a set of 241's for basically free.. im putting them on my 98 camaro (had the 806 castings).. i had the 241's milled .028 to get me the 63cc's i was looking for..
springs are up to you and your cam selection...
Old 04-25-2007, 05:53 PM
leoni62486's Avatar
ttt for some more input please
Old 04-25-2007, 06:11 PM
styoung's Avatar
what is the difference in the two castings?
Old 04-25-2007, 06:14 PM
Studytime's Avatar
Run the stock lifters, Patriot dual coil springs, stock rockers, and the felpro .042" gaskets. Get the milled as much as you can and still have adequate valve-to-piston clearance.
Ben T.
