How high should I spin my stock cam?
I use to think 6600 rpm was fine but I was wondering if the powerband had dropped off at a lower RPM and if I was actually hurting myself as far as performance goes? Thank you.
What engine to you have in the 1st place an LS1, LS6 or an LS2 because they are different beasts in this deparment. 6,600 seem too high for a stockish LS1 I think something closer to 6100-200 would be alot better 6,600 would be a better shift point on either a LS2 or an LS6. I don't even rev my 32v 4.6 past 6,600 and my engine peaks higher than any stock LS1.
Yea then you really can keep it under 6 grand with an LS1 maybe if you had LT's and a full exhaust you could stick with 6,100 but why stress your parts more for nothing truthfully I wouldn't even rev an LS2 to 6,600 because it pretty much falls off around 6,000 but some people don't really care I know guys that rev their Mach 1's to 7 Grand which is dumb because they peak in the mid 5,000's
Originally Posted by lt1formula2000
I say the stock limiter is probably high enough for a stock cam and stock springs. so I guess I would say between 5700 and 6000
