AFR 225 heads
Old 05-01-2007, 10:20 PM
BlueFish's Avatar
Default AFR 225 heads
I have these heads and need to find out what the chamber size is. The heads have the number 150 on them if this will help with anything.
Thanks.
Karn
Old 05-02-2007, 05:02 AM
vettenuts's Avatar
Contact Tony Mamo directly, he can help you out. Other option would be to measure them.
Old 05-02-2007, 05:17 AM
Studytime's Avatar
Take them to a local shop that has a machine to mill/deck heads. They'll be able to CC them for you. That's the best and most accurate way to check.
Ben T.
Old 05-02-2007, 08:53 PM
BlueFish's Avatar
Thank you guys.
Old 05-03-2007, 02:54 AM
ScatStroker's Avatar
More than likely they're large chambers but there is a bar code on the end of the heads, get the number from that and contact AFR - They'll tell you how they left.
Brian
Old 05-03-2007, 10:00 AM
slt200mph's Avatar
Turn the heads upside down on your bench and put a level on them to make sure they are level. Get a serenge from your local drug store and use it to fill the chamber with liquid and total up the CCs...or call Toney on the phone..either one should work..
