looking for info on offset ground cranks
Old 05-05-2007, 10:21 PM
383ss's Avatar
Default looking for info on offset ground cranks
I've spent about an hour searching and cant find jack squat. I know years back they were talked about quite a bit, but I can find no information.
does anyone know how much it costs, how much it increases stroke and how much it weakens the crank?
this would be for a strickly NA application.
TIA
Old 05-05-2007, 10:31 PM
Beast96Z's Avatar
I know TSP used to have a offset ground crank option. I believe they gained about .100" stroke on a stock crank. When taking a 2.100" journal down to a 2", I don't think your really "weakning" the crank to much. Alot of high perfromance cranks run 2" journals. I do believe they need to be re-heat treated after cutting though. Not sure on the cost, but there are some nice rods out there for a 2" Journal.
Old 05-06-2007, 09:08 AM
383ss's Avatar
cool, thanks. I'll give TSP a call.
if your going from 2.1 to a 2" journal that is only a .05 gain in radius, so I beleive that is only a .05 gain in stroke.
Old 05-06-2007, 10:48 AM
LS1Formulation's Avatar
LS1Tech 10 Year
It's all on ONE side of the crank though. So you gain more.
Old 05-06-2007, 11:31 AM
383ss's Avatar
ok, thanks. that makes sense
Old 05-08-2007, 05:05 PM
383ss's Avatar
well, TSP will no longer do offset ground cranks. I didn't get any info on why though.
Old 05-08-2007, 05:17 PM
TA2SLOW346's Avatar
I used to run one, .070 off set in my 393 motor. There is a place in ST.Louis that can do it.
Old 05-08-2007, 05:26 PM
383ss's Avatar
cool, pm sent.
Old 05-08-2007, 11:46 PM
mypoorLS1's Avatar
The reason they don't do it much anymore is because the cost of stoker cranks has went way down when eagle started selling cranks. For the same cost you can have a 4in stroke. I was looking into it as well.
Old 05-09-2007, 07:57 AM
AINT SKEERED's Avatar
i am looking at this as well. smaller journal slows bearing speed. What cube can you get with a 4.030 bore and offset grinding to 2.0 journal?
Old 05-09-2007, 05:27 PM
TA2SLOW346's Avatar
You get about 9-10 cubes depending on your bore size.
