LQ4 vs LQ9 piston/rod weights
Old 05-11-2007, 11:12 AM
ChevyThunder17's Avatar
Default LQ4 vs LQ9 piston/rod weights
Well, I want to bump up the CR on my 6.0 liter and while I could buy aftermarket pistons and rods, get it balanced, etc. I wanted to see if swapping out the pistons and rods of an LQ9 in place of the LQ4 piston/rod combo would be possible. Would it require a rebalancing of the crank?
I've searched for the past two days and I haven't found any conclusive info on it, so I'm hoping that someone will chime in.
Old 05-11-2007, 11:41 AM
sroach20's Avatar
im putting an lq4 in my z28 and was told that what you pick up is not worth the money and effort. check on performance trucks, theyll explain it.
Quick Reply: LQ4 vs LQ9 piston/rod weights
