guys with 5.3 heads and 987 springs...
Did you use your stock pushrods? and also stock valve keepers? (this is with a TR230 cam)
Thanks <img src="https://ls1tech.com/threads/images/graemlins/cool.gif" alt="" />
Re: guys with 5.3 heads and 987 springs...
Used aftermarket pushrods but they are the stock 7.4 in length. The amount milled and base circle of the cam offset each other. Installer checked etc and 7.4 was right for my set up. Not sure what TEA used for the keepers.
