408 stroker with hp turbo kit
Old 05-12-2007, 09:21 PM
turbo408stroker's Avatar
Default 408 stroker with hp turbo kit
i am installing a hp stage 3 76mm turbo kit on a built 408 with 75lbs injecters with a sump tank with new lines magna fuel pro tuner pump rated to 2000hp fuel rails i will be using ls6 intake and stock 6.0l heads and a duel nozzel elky control meth injection kit my comp is 9.0:1 what kind of power sould i be able to get out of this setup trying to get to run 20 lbs of boost at the most
