Buyin new cam, whatelse?
Old 05-20-2007, 08:27 PM
99taracer's Avatar
Default Buyin new cam, whatelse?
Im playin on gettin a Comp Cams Xtreme RPM 220/224. But before i get in too deep im ask all you on whatelse i should get to make the valvetrain a complete package. Oh and btw i have a 99 ta with 79k miles, all stock internals. Have added BBK SSI intake, slp loudmouth2 exhaust, ported tb.
Thanks for ur input.
Old 05-20-2007, 08:35 PM
'02 WS6's Avatar
some 918 comp springs, and 7.40 chromoly pushrods, ls2 timing chain, and an ls6 ported oil pump should get you set. don't forgot the extra crank bolt and timing cover gasket too!
Old 05-20-2007, 11:41 PM
dnm12's Avatar
check out my page 7 for some ideas or page 10 but above is a pretty good setup
Old 05-21-2007, 07:57 PM
99taracer's Avatar
For new springs i was thinking about Patriot Gold Extreme Valve kit for ws6project.com, should i look into to rocker arms or roller lifter, and for the ls2 timing chain - will i need new spockets or stock will do. Anyone know of any good deals on ported ls6 oil pump.
Old 05-21-2007, 08:42 PM
'02 WS6's Avatar
you'll catch some oil pumps on here pretty frequently, along w/ the ls2 chains. and my theory w/ the sprockets is similar to dirt/street bikes, when i do the chain...i also do the sprockets! your stock rockers and lifters should be fine, but ls7 lifters and some harland sharps aren't too bad of an idea, but not necessary.
