6.0 heads
6.0 heads
Anyone know where to get stock 6.0 heads?
Also, what CR would they be on a stock bottom end LS1?
With these heads, if I wanted to make the whole setup 9.0:1, what CR pistons would I need to get?
Thanks!
Thanks!
!Dial-up Director
Re: 6.0 heads
Email indacalinc@attbi.com for 6.0l heads
For piston talk to chris at Diamond pistons on the right. Tell him what you are using and he will get you the piston you need.
To figure compression ratio try this
http://www.bgsoflex.com/cr.html
6.0L heads are 70cc, stock bore is 3.90, stock stroke is 3.622, gasket is your choice ( .045-.054 ), piston top volume would be 0 for stock pistons and +8.7 for the off the shelf diamond boost pistons.
Justin
Justin
