thinkin for swappin 205s for 225?????!
Old 05-24-2007, 07:08 PM
camarokid94's Avatar
Default thinkin for swappin 205s for 225?????!
so after all the 550HP 500TQ cars im just wondering if its worth it for my to get some AFR 225s maybe a little bigger 250-254 113+3 cam maybe something like that.
or in reality just be happy with it and see what the track brtings. and the 200SHOT.
But i get the internet bug when seeing all the 550HP stuff. i dont know.
i guess i should just stop reading the dyno section and spend more time on the TRACK section...
so my question is it worth the money and time for the 50HP i MIGHT get no guarentee on it
Old 05-25-2007, 02:28 AM
staringback05's Avatar
i think you should go ahead and go for it and get the most out of them
Old 05-25-2007, 03:04 AM
DONAIMIAN's Avatar
I say you should run it at the track first. If all you think its worth is 50hp then I say just spay 50 more in nitrous.
Old 05-25-2007, 03:08 AM
cowboysfan's Avatar
if you think the money warrants it and can afford it. then hell yea!!!!
Old 05-25-2007, 09:09 AM
see i think thats what i need to do. if it goes 11.2 N/A or better ill be happy. maybe 10s who knows. if all else fails that 200 shot will kick in and something cool will happen for sure.
Old 05-28-2007, 06:00 PM
00Formula00's Avatar
hey man little off subject, but if you do go with the 225's, I'd buy your 205's off you...
Old 05-28-2007, 06:43 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
Stick with the 205's in a stock displacement build....
With the right combination of parts you can achieve 500+ RWHP.
Thats about all the money from a pump gas 346 hydraulic roller motor.
If you want more than that start looking at some stroker packages.
You will not see a big gain upstairs with the swap but will regret the loss of low and midrange snap.
Save your money and stick with the 205's....
Tony
Old 05-28-2007, 07:01 PM
Brads LS1 02Z's Avatar
Tony
just wondering if u saw in his sig that says 402???
Old 05-30-2007, 01:02 PM
yeah i think he must have missed that part
Old 05-30-2007, 05:03 PM
Flow Wizard
A minor oversight....LOL
Actually reworking the 205's is still an option (to maximize the larger bore) and strong results have been posted with a few 402's without even doing that, but certainly an aggressive 402 build would warrant and make good use out of a 225.
Camaro Kid, I know we went back and forth on an intake awhile ago (forgot about the stroker and didnt notice it in your sig) so feel free to pick up the phone or PM me if you would like me to more clearly explain the differences between the two. Already having the 205's in hand makes the decision on which way to go not as cut an dry.
(661)257-8124 Ext. 109
Cheers,
Tony
PS....For those running a stock displacement dual purpose vehicle, my advice above certainly still has merit.
Old 05-30-2007, 06:26 PM
yeah i thought about callin today, i might tomorow, i need some sound solid advice.
what happens if nothing else changes only my runner size. compression stays the same as i like my bottom end just would like more up top since it does die down above 6100. keeping the cam should keep my bottom end ok i checked what DCR would be with say a 250-254 112+4
and it goes from 8.5 to 8.34????? humm what to do
Old 05-30-2007, 07:41 PM
Flow Wizard
Call me tomorrow...
I've got a few ideas cookin for you....
Tony
PS....The car would have to be down for a few weeks to a month though. If your looking for hero track times having it ready for the fall would be good for obvious reasons.
Old 06-15-2007, 10:37 PM
eb02z06's Avatar
Tony what about stock displacement with a blower-I'm a 920rwhp@5900 rpm with a F1R, Patriot CNC "243" head-stock valves. I want AFR's-I ran them in the past with mega results-do I go 205 or 225?
thanks!
Old 06-15-2007, 11:14 PM
Hennytime's Avatar
thanks!
bet ya a dollar he says 225's
Old 06-16-2007, 11:26 AM
eamador11's Avatar
I missed it too...most guys go 225s as soon as the ci is above 396. wonder why he didnt go that route from the beginning.
