who does a good head porting
Old 05-28-2007, 07:20 PM
chromeplated500's Avatar
Default who does a good head porting
Ive had severe search problems. But I want to get my heads ported and I wanted peoples opinions and just a list of a few that i could check out...
I checked out Elliots, ETP, and Trick flow... but are there others?
does anyone have first hand experiece or just infor in general
thanks in advance.
Old 05-28-2007, 07:27 PM
vanilla89's Avatar
www.eportworks.com Lloyd does all my heads
Old 05-28-2007, 08:50 PM
Bo White's Avatar
There are too many to list really. Some go with the most popular, some go with the most expensive and some go with the cheapest. The main thing is to do what your doing now(getting opinions) and then going from that on whats important to you: price, flow, port size, valve size and brand/type, type of casting, type/brand of springs and size of chambers for desired compression ratio.
Old 05-28-2007, 08:52 PM
transamfreak01's Avatar
what type of heads??? are they the stock ones?? if so port work the is good is expensive. for a little bit more money you can get a set of new heads that will run a lot better than stock ported ones
Old 05-28-2007, 10:11 PM
853s... from what ive heard a good ported set of these can flow with the best of them..
Old 05-29-2007, 07:45 AM
Wonderbread's Avatar
I would give Brian Tooley at Total Engine Airflow a call. Those guys do some amazing work. I know they are working on a new program for 853's. www.totalengineairflow.com
Old 05-29-2007, 08:23 AM
PREDATOR-Z's Avatar
MTI as well
Old 06-01-2007, 12:45 AM
well thanks, gives me somethings to check out.
