Head bolt pitch/size???
Old 06-04-2007, 05:01 PM
PewterWSSicc's Avatar
Default Head bolt pitch/size???
I need to know what size are the head bolts and what is the pitch of the threads? I need to clean out the holes and dont wanna wait for an ARP bolt chase. So i wanna go to a local hardware store and buy a tap.
I know about the old bolt trick, but somebody threw my old bolts away. So I need the tap. I tried to search it, but the search engine isnt working for some reason.
Old 06-04-2007, 08:27 PM
LS1MCSS's Avatar
I use the nylon brushes at the link below. You can order the size you need and they are cheap. Use one of these and a can of carb cleaner and you can clean all your bolt holes in under 20 minutes. I actually have a couple of spares, if you need one. http://www.goodway.com/accessory/548-gtc-211.aspx
Old 06-05-2007, 12:06 AM
405HP_Z06's Avatar
M11 x 2.0 and M8 x 1.25
Old 06-05-2007, 08:12 AM
GuitsBoy's Avatar
You can also notch out a stock head bolt to use as a thread chaser...
