F1 cam
Old 06-06-2007, 11:27 PM
solo21's Avatar
Default F1 cam
can anyone help me...what do you think about the F1 cam? and what kind of heads would you recommend for it?
Old 06-06-2007, 11:28 PM
N2OGTO's Avatar
way wrong section...
go to gen 3 internal engine...
Old 06-07-2007, 12:49 AM
waldershrek's Avatar
Old 06-07-2007, 07:40 PM
Bryan28's Avatar
Default Good Choice
I picked up a used F-1 a few years ago, its considered an ''old'' grind nowadays, I think it first came out sometime in 2002 and Speedtek marketed this cam. Its a Lunati brand cam that Speedtek put its custom grind into. If you are going from a stock cam to this cam, you will get a good power increase from 2500-6500.. I had my car tuned after this cam and it really helped with Cam Surge and drivability issues.. I am running stock heads and comp 918's with no problems! If you have off road exhaust you will get a noticible stinky idle also.. But that's the trade off in power! You will also get more cam surge. It has a nice lopey idle since its on a 112 lobe center with Plus 4 degrees of advance.
Quick Reply: F1 cam
