Returning a cam?
Old 06-08-2007, 04:56 PM
CMKworm's Avatar
Question Returning a cam?
So if you order a cam and clay it and it doesn't fit, can you return it or what?
Old 06-08-2007, 04:57 PM
Beast96Z's Avatar
I highly doubt it. If the cam has been installed, it's yours. Luckily, cams sell fairly quick in the FS section, so you'd only loose a little on your mistake.
Old 06-08-2007, 06:09 PM
CaMaRo67RS355's Avatar
call me stupid what does clay mean?
Old 06-08-2007, 07:00 PM
mrr23's Avatar
you put clay on top of the piston, install head, turn the motor over. take head off. check the thickness of the clay to see how much piston to valve clearance you have.
Old 06-08-2007, 07:59 PM
CMKworm's Avatar
I guess I'll make sure it will fit!
