6.0 LQ9 short block, pistons and rods?
Old 06-12-2007, 08:40 PM
camaroracerlt1's Avatar
Default 6.0 LQ9 short block, pistons and rods?
Hey, I am building a 6.0 LQ9 truck motor with the L92 top end. I want to do .040 over forged flat top pistons with h beam rods. Is there some way to use standard small block pistons and rods for this or do you need dedicated LS1 style parts. If so what pistons and rod length is required. I am trying to keep my rotating assembly as light as possible because I want to go to 7500 rpm. Also if anyone has built a similar motor can you suggest a good off the self cam for this set up? I'm new to LS1s so any other pointers are apriciated. I haven't been able to get the search function to work (I think it times out because I have dial up or something) so I'm sorry for posting if this has been covered before. Thanks in advance.
Old 06-12-2007, 10:03 PM
LS1 Tech Administrator
Patrick G's Avatar
Moved from advanced tech section.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 06-12-2007, 10:44 PM
SUTTERERMAN85's Avatar
i was going to use some sbc style rods from scat but SDPC has the on center i beams from them for like $300 with 7/16 arp rod bolts so thats what i went with
Old 06-13-2007, 11:17 AM
camarokid94's Avatar
why do u want to get away from the GENIII stuff ? i dont get it
Old 06-13-2007, 01:22 PM
5.3LJimmy's Avatar
There isn't enough sleave to bore a 6.0 0.040 over. I'm sure you can use SBC rods, but I'm not sure what piston/rod combo's are available w/ the correct pin height. You are probably better off buying parts designed for a GEN3.
