A quick question about installing the rear cover...
Old 06-13-2007, 10:02 PM
Mike94ZLT1's Avatar
Default A quick question about installing the rear cover...
When I installed the covers on my engine, I did the oil pan first, using straightedges on the back of the block to line it up for the trans. Got it perfect. Then, when I put the rear cover on, I used a small pick and carefully seated the new rear main seal, then let the seal center itself on the crank, and torqued it to spec. Anyways, some bs happened and I had to drop the pan. I had the engine upside down today, and I noticed when I was getting ready to put the oil pan back on it was not completely flush with the bottom of the block, and I'm afraid it will leak. I dont want to pull it off and push it down level, because then the rear main seal wont be centered over the end of the crank. What do I do?
Old 06-14-2007, 12:23 AM
I can shift faster than you.
Jason99T/A's Avatar
When installing the rear cover, you need to pull the cover down flush the the oil pan with the two long bolts (M6x1.0; pan to cover bolts) first before tightening the cover to block bolts (M8x1.25). I get all the M8x1.25 bolts started just barely hand-tight, torque the M6x1.0s to 106 lb-in and then torque the M8x1.25s to 18 lb-ft. This will ensure the rear cover is pulled down flush with the oil pan.
Jason
Old 06-14-2007, 12:58 AM
Mike94ZLT1's Avatar
Jason
Thanks Jason, but won't that make the rear main seal off centered on the crank?
Old 01-30-2008, 10:57 PM
lilbuddy1587's Avatar
Jason
Does anyone happen to have the GM PN for these bolts that I have bolded? I snapped one when I was taking it out. I have tried hardware stores but to no avail.
Anyone?
Old 01-31-2008, 12:42 PM
Beast96Z's Avatar
The seal will have more forgiveness than the misalighned aluminum. I always do it like Jason described above.
