afr spring question
afr spring question
has anyone ever heard of the dual coil springs on the AFR mongoose heads (the ones good to .600" lift) setting off the factory knock sensors? i know that this can happen with some after market springs and i was just wondering...also, do you think these springs will be okay in a high"ish" rpm engine (7000rpm redline), i'd like to check their site but its under construction or whatever.
LS1 Tech Administrator
The standard 8017 spring from AFR is the same as the Patriot Gold, PRC duals, and Manley duals. It is good from cams in the low .600"s and will easily rev to 7000 rpm with proper pushrod length and lightweight rocker (like the stock rockers).
It is not known for setting off knock sensors.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Would need to know what cam you're running, how much your heads have been milled, how thick your head gasket is, what lifters your'e running and what rockers you're running.
__________________
