questions about heads
so i am planning on a build using a 98 block. will any of the later center bolt heads bolt right on. mainly a 6.0 liter head? also can you use the fast 90/90 set up with a 6.0 liter head or are the intake ports diffrent
cliffs:
using a 98 ls1 block
6.0 liter heads
fast 90/90 intake
will this all work togeather. i only ask becasue i have been told the 98 heads use different headbolts than the 99 and later. i will not be using 98 heads on this 98 block. all info would be greatly appreciated
cliffs:
6.0 liter heads
fast 90/90 intake
Yes you can use the later style heads on your block with no problems, just use head gaskets for the later style as well, I think the 1998 gaskets are slightly different. The 6.0 litre heads will work too!
