Iron block 422. Power #s?
Old 06-28-2007, 10:26 PM
Indiana Z06's Avatar
Default Iron block 422. Power #s?
I'm having a 6.0L iron block 422 stroker built as we speak. I'm using Eagle rods, crank and Diamond pistons. For the heads, I'll be using the Trick Flow 235cc with Harland Sharp roller rockers. My SCR should be approximately 11/1. For the cam, I'm thinking of using the Texas Speed 248/254 .611/.613 114 LSA. I'm having to use an LS6 intake and LG Street Series headers for now. I know the intake and headers are holding me back but my wallet only goes so deep. I'm hoping for an easy 510 rwhp for starters. What do you guys think? Thanks!
Mark
Results in post 8
Old 06-29-2007, 12:01 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Is it 4.030 bore / 4.125 stroke or do you have some odd combination? I don't think eagle makes a 4.125 crank only a 4.100 and 4.250 IIRC?
Old 06-29-2007, 01:41 AM
I know the block is being bored 60 over but I'm not sure what the crank size is. My builder has all of the specs.
Edit: I thought it was 60 over, but it's only 30.
Old 06-29-2007, 06:10 AM
slow trap's Avatar
i think a 4.06 " bore with a 4.1" crank is almost 425 cubes.
i think you are pretty close on your figuring of 510 rwhp or so. the ls6 will be a major restriction. a ported 90/90 setup should get you up around 550 rw or so imo.it should be a strong setup when you have all the right parts on there.
Old 06-29-2007, 06:40 AM
King James's Avatar
I think you need to get a hold of me when its done so I can go for a ride!
Old 07-08-2007, 07:45 PM
Here are some specs so far. Had to make some changes.
Bore: 6.0L iron block 4.030"
Crank: Eagle 4.125"
Rods: Eagle 6.20"
Injectors: 42lbs
Pistons: Diamond -7cc
Heads: TFS 235cc
Intake: Ported FAST
Headers: LG Street Series
Cam: G5X4
My rotating assembly is being balanced now. Hopefully, I'll have it running around the middle of August.
Old 07-08-2007, 07:49 PM
OWN3D BY MY PROF!
I like that setup mutch better than the above mention 4.06 bore. I want to build something like exactly like that, except solid roller.
Old 11-29-2007, 11:30 PM
Well, I finally have some results. With the 421 stroker, 11.2/1 SCR, TFS 235cc heads, G5X4 cam, FAST intake, ported 90mm TB and LG Street Series headers, we're making 498rwhp and 507rwtq. This is on a Mustang Dyno. I don't have any driving impressions yet but hopefully will by this weekend. We'll see what happens.
Old 11-30-2007, 07:12 AM
slow trap's Avatar
that is pretty good numbers for a mustang dyno,especially the torque.
Old 11-30-2007, 08:44 AM
BerryWS6's Avatar
I got a friend that has a 422 resleeved LS6 block and with 90/90 and AFR 225s, bigger cam and a great tuner he did 550rwhp and 505rwtq!
Old 11-30-2007, 11:38 AM
KCFormula's Avatar
I have a simliar setup only with a solid roller and it makes peak power at 6200rpm. The ported FAST still isn't enough to keep up with the lower end.
Old 11-30-2007, 11:42 AM
OWN3D BY MY PROF!
Sounds like some good results. I still want to build a setup like this.
Old 11-30-2007, 05:51 PM
Firehawk441's Avatar
Great #'s. Glad to see more people are using this bore/stroke combo.
