opinions on new setup being built
new heads cam setup
currently putting together a new setup for my 99ss/m6 .stock block 28xxx miles picked out of a 01 vette , afr 205 heads, 228/228 on 113lsa chromoly pushrods, lifters, double roller timing chain, high vol oil pump, 30 lb injectors, pacesetter headers, ory, fast 90 nw 90tb,dyno tune at synergy. just want to hear what you guys think about power and driveability because this will be a daily/occasional run at the track. running slp lm.
- cris
- cris
Looks very similiar to the set-up that i am working on...Even the same place for install and tune ...Although mine is going to be a little more raced out(bigger cam, higher compression)...Set-up looks good...You should dyno 425-440RWHP and 385-400TQ with that cam...Give or take...If you havent done any suspension work yet, I would reccommend doin that first since you car is a daily driver...Definetely get a new rearend in there since you are an M6...Don't forget about a new clutch too...Besides that everything looks good...
Kev
Kev
