02 Z06 Cam vs 03 Z06 Cam?
Is there any difference in the two cams? Does anyone know the specs? Thinking of using it for my single turbo car. I have a 224/228 588.595 on a 115lsa that i was going to install. What do you guys think. Its a forged 347 with 8.6:1 with a 3000 stall 4l60e.
Also should i use the adjustable crane dual timing set that the guy im buying the motor from is including. Or should i sell that and get an ls2 set?
Alex
Alex
LS1 Tech Administrator
The '02 and '03 Z06 cam are the same. The '01 Z06 cam is the smaller one and it's the same cam you'll see in stock LS2s.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
The 224/228 115LSA cam will work much better for a turbo car searching for big hp. The LS6 cams will work OK, but they are not ideal. I'm seeing lots of turbo cams anywhere from 225/225 with 113LSA to 224/230 cams with 114LSA. You need to watch your intake centerline to make sure you center your overlap right over TDC.
__________________
