cheatr cam sound
cheatr cam sound
does ne one know what it sounds like im looking into maybe getting it but i want it to be stealthy and not look like i have nething done to the car i currently put down 348hp and 365tq the way the car sits.. what might my hp gains be?
yes i did my friend has it,the cam sound stealth on the stock headers and cat back
but after my friend swap for LTheaders the car start to idle like a 114lsa cam it has a choppy idle?
so if you are getting it make chure at least you have your stock cat back on
that cam could get you to 380 hp with no problem.
What sound clips, that always cracks me up. It is a very wide LSA cam, no lope. What you'll hear is the exhaust depending on which setup used and at what rpm is the idle set.
Disregard old videos. Here's a video of the CheaTR cam in ls1 equipped rx7 with AFR's and spray, running 9's. Can't hear the idle but you see what it can do with heads, some spray and some weight reduction lol . (The video link is in the second post)
http://www.v8rx7forum.com/v8-rx-7-bu...ild-check.html
Originally Posted by transamfreak01
hahaha yeah i know i love when people ask to hear a sound clip of a cam that is supposed to sound stock. listen to your stock car and itll be the same thing
Originally Posted by deeloc1
Hahaha...i love it when Pred-Z makes a comment and them someone makes one right after him just to kiss a** and act like that's what they were thinking all along. Lol. read some of pred-z's posts and your comment will be the same thing Give the guy a break. If you listen to some of the sound clips i posted it doesn't sound stock.
Probably cause you didn't post a single video clip of the cheater cam, you a a much laarger cam with a much closer lsa. Good job S A ! ! !
im just wanting to hear a sound clip cause it is hard for me to believe that it sounds stock.. im thinking about going with it and i appreciate the people trying to help me but if you dont have nething positive to say then you can stay out my thread... thanks everyone else
It doesn't sound completely stock. It has more overlap than stock on the NEGATIVE side. It is a Stealth idle. Put it on a stock exhaust setup and if you can make the 2 out (unless you're an engine maestro) take what you want. A trained ear can discern the faster tempo, that is all.
