What Numbers To expect With the MS3??
Old 07-09-2007, 05:52 PM
Prerun4fun13's Avatar
Default What Numbers To expect With the MS3??
I have a two part question and i tried the search and it gave me a 408 time out deal. So my first question is will i need bigger fuel injectors when going with the Magic Stick 3? I know im getting an LS6 intake, long tube headers, true duals, ls6 ported oil pump, LS2 timing chain, push rods,gaskets, and dual valve springs. If there is anything i left out let me know, but basically what i want to know is if the stock injectors on my 99 camaro are suitable.
Question number 2, is what kind of numbers should i expect at the wheels after a good tune?? I have heard over 400 rwhp. So any input let me know please.
PS: If you have an LS6 intake, long tubes, true duals, or any other parts i may need for sale let me know as well.
Old 07-09-2007, 06:08 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Over 400 at the tires is a good estimate. I would upgrade to atleast 30lbs injectors just to be on the safe side.
Old 07-09-2007, 07:34 PM
sedanman's Avatar
I have a MS3 on a 111 lsa with longtubes and 3" but still stock ls1 intake (LS6 or fast coming soon) on my 99 TA. I had my car street tunned and it didn't max the injectors but it came close 96% duty cycle (if I remember right) so I am probably gonna do 30 or 36# at the same time I do the intake just to be safe.
Old 07-09-2007, 10:00 PM
Closed Sponsor Account
ERIK@MASPORT's Avatar
I run an MS3, but have head and a bunch of other goodies to go with it...I run 42# injectors, and they are just right..
To be safe, and ready for more power later, add a racetronix fuel pump and some 30# injectors...that way, you can always add some more power later and be on the safe side.
You do not want to go lean with this cam, it makes power @ 7000 rpm, I know...check out my dyno vid (7200 RPM)
Erik
Old 07-09-2007, 11:00 PM
01 BERGER CAMARO SS's Avatar
I have an MS3 an upgraded to 36 pound injectors and ran perfect.
