Yella terra's with Double springs?
I bought them, for my H/C setup, but never thought about this. Will I have any issues with running them with my double valve springs? God I hope not, It seems lately, that everything I start, turns into a 3 month PROJECT .
Re: Yella terra's with Double springs?
They should clear the double springs themselves with no problem. The one problem I have had is with other vendors heads that either have a longer valve or lash caps. This would raise the valve tip end of the rocker and cause an interference problem with the valve cover.
Mike
Mike
don't know the answer to double springs but I FEEL YOUR PAIN!!! Every dinky pud little thing I try to do has been leading me out to the woodshed for a severe spanking.
You're almost done..?
