what are good flow numbers?
what are the normal flow numbers for stage II heads nowadays? i found some with these #'s for pretty cheap...just seeing if they are any good, thanks.
Int Exh
.100 67 64
.200 140 108
.300 199 149
.400 242 185
.500 276 207
.550 290 216
.600 296 223
Int Exh
.100 67 64
.200 140 108
.300 199 149
.400 242 185
.500 276 207
.550 290 216
.600 296 223
Re: what are good flow numbers?
its a SUPERFLOW 1020 digital flow bench btw are these any better?
.100 72 64
.200 150 108
.300 207 149
.400 252 185
.500 279 207
.550 288 216
.600 XX? 223
thanks
.100 72 64
.200 150 108
.300 207 149
.400 252 185
.500 279 207
.550 288 216
.600 XX? 223
thanks
depends on cam lift.The area under the curve is better on the second set you posted if only using a .550 lift cam.Although with a 4 cfm increase on the same bench for the .100 number I would almost guess they had a slight leak.
Brent
Also I think a head that flows more midlift numbers will work better when used with an intake on a car.
Brent
